Dynamic Simulation: placed part is grounded when it should be free to move
bender.terry
Message 1 of 8
bender.terry
I am placing SolidWorks generated parts into an assembly and providing mates, etc. Some parts I don't mate and instead wait to "Insert Joint" within the Dynamic Simulation environment. Anyway, these must move, but they come in under Grounded. See attached screen shot. How do I unground them, like moving to Mobile Groups, etc.? If I right click in Dynamic Sim, or the Assemble environment, Ground is not checked.
Replies (7)
Message 2 of 8
johnsonshiue
Hi! Could you share the files here? There should be a logical reason to explaining the behavior.
Many thanks!
Software Test Engineer
Message 3 of 8
TheCADWhisperer
For image to be of any use - you would need to expand to show the Constraints.
My guess  would be right click Retain DoF.
Message 4 of 8
j.palmeL29YX
Add any joint.
In the assembly environment all parts have 6 degrees of freedom and we can reduce some/all of it adding constraints.
In the Dynamic Simulation all parts are initially fixed and get their degrees of freedom by adding joints.
cadder
Jürgen Palme
Message 5 of 8
TheCADWhisperer
@j.palmeL29YX wrote:
Add any joint.
What if automatically converting assembly constraints to Dynamic Simulation Joints?
Message 6 of 8
bender.terry
Find attached the SW part as brought into Inventor Pro. Query the part, etc.
I'm new to Inventor and can't find where I can assign DOFs or make un-Grounded in Dynamic Simulation.
Some parts I brought in were not made Grounded. Others, it seems, are Grounded by default like the attached sample. Sorry I can't provide assy; it's proprietary. I did nothing different from importing one part and another into the assy, just used Place as reference part or not.
All I need are steps to make any Grounded part un-Grounded so that the part will move under the influence of gravity, spring force, force, contact, or any combination of these.
When using 2018 a few months ago, I did not run into this problem. I took 2018 down when I installed 2019.
Terry
Message 7 of 8
j.palmeL29YX
Add any joint.
See the attached video https://autode.sk/2QZSpB8. It is a simple example which shows the principial behavior. I cannot open files which are newer than IV 2015 (so also not yours) , but I think this video shows what I meant. Of course you should add instead of the spatial joint a joint which is useful for you.
cadder
Jürgen Palme
Message 8 of 8
TheCADWhisperer
@bender.terry wrote:
Find attached the SW part ...
A SolidWorks part file has the extension *.slprt not *.iam
A SolidWorks assembly *.sldasm must include part files *.sldprt
An Inventor assembly *.iam must include part files *.ipt
