Inventor Forum
dwg to 3d SOLID
8 REPLIES 8
Message 1 of 9
EbbeFN
2051 Views, 8 Replies
dwg to 3d SOLID
Hi everyone
I need som help on converting an autocad-file to 3D solid in inventor (2015).
Its 3d when opened in AutoCAD - or it looks like (i'm an amateur to AutoCAD) - but I cant export it to sat ?
When trying to import the dwg into inventor I just get an empty file (i can open the dwg in inventor - and it works just fine - is pretty useless though)?
Can anyone give me a clou - im generally NOT impressed when importing dwg to inventor - but maybe its just me ? Will it be any easier using solidworks (got an license temporily) ?
Thanks Ebbe FN
8 REPLIES 8
Message 2 of 9
asiteur
in reply to: EbbeFN
I agree that importing DWG's from other CAD applications is not very smooth although from other Autodesk products it should be fine.
Else I generally draw the thing again.
BUT, in your case I actually got quite nice results:
So I imported with the following settings:
I attached the new ipt (which probably needs the DWG as reference)
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
Message 3 of 9
TheCADWhisperer
in reply to: EbbeFN
@Anonymous wrote:
.... im generally NOT impressed when importing dwg to inventor - but maybe its just me ? Will it be any easier using solidworks
The issue has nothing to do with Inventor or SolidWorks.
The original geometry is not solid geometry, but rather mesh geometry (and poor quality at that).
Trying to work with something like this is sort of like putting lipstick on a pig, it will still be what it is...
I am not impressed with the source geometry - I would start from scratch using this geometry only for reference.
Or request proper geometry from the source.
Message 4 of 9
TheCADWhisperer
in reply to: asiteur
The *.ipt file you attached is coarsely faceted planar surfaces?
It would take about 30 minutes to model this geometry properly.
Message 5 of 9
EbbeFN
Looks nice - BUT I tried to replicate this by using the settings you have attached (thanks 🙂 ) - but nothing happens - I still get an empty part when importing the dwg into inventor. I must be missing something ???
I am on inventor 2015 - could that be the problem ? (I will update shortly) - or is something rotten in my system ?? I have similar problems importing 2D dwg's - but its allways been like that 😞
Ebbe
Message 6 of 9
asiteur
in reply to: EbbeFN
I used INV2015 Pro, so I don't think that's the problem.
I did my import from the Part environment, not the drawing environment, maybe that is the difference?
As I said for me is importing DWG's also hit-and-miss so if this doesn't help I wouldn't  know what the issue could be.
As said by efn, it might be easiest to just recreate the shape in inventor, it's pretty basic.
Alexander Siteur
LinkedIn
Message 7 of 9
TheCADWhisperer
in reply to: EbbeFN
@Anonymous wrote:
... I have similar problems importing 2D dwg's - ...
Create a Screencast of your steps.
Using dwg (2D or 3D) is easy when you know how.
Also, attach any file here that you have trouble importing.
Message 8 of 9
EbbeFN
Tried again in different ways - just changed the "Detected units" to "specify units" as mm. Now it works - THANKS !
Vh Ebbe FN
Message 9 of 9
EbbeFN
in reply to: TheCADWhisperer
Hi
Thanks for the offer - now the first problem is partly solved (may have to do a quick rebuild as you mention) - but I think I will mail you next time I have to import a 2D DWG 🙂
Vh Ebbe FN
