- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I'm trying to use linking parameters to drive dimensions of parts from an assembly. I've read some other threads about it but I still don't understand how to do it. Here is my simplified example:
I have two files:
- TestPart.ipt
- TestAssembly.iam
TestPart contains a simple cyllinder with diameter 10 mm and height of 100 mm. Height of the cylinder is defined by the named parameter "Height". TestAssembly.iam contains nothing other then a user parameter called "Extension" equal to 0 mm
I want to insert TestPart.ipt into TestAssembly.iam and increase the height of the cyllinder from 100 mm to 200 mm by changing the value of the "Extension" parameter in TestAssembly.iam from 0 mm to 100 mm.
______________________________________________________________________________________
What I've tried so far:
- Linking "Height" parameter from TestPart to TestAssembly. Parameter is greyed out. Turns out you can't drive the geometry of a part directly from another file (per other threads about the subject),
- Reversing previous attempt. Setting "Extension" user parameter to 100 mm, linking it from TestAssembly to TestPart and setting Height in TestPart to "100 mm + Extension". I have no idea why it doesn't work but Inventor warns me about "cyclical references" and doesn't allow me to insert TestPart into TestAssembly
- Using both methods described above but using derived components as intermediaries (to the same effect).
I know one can use other methods (iLogic, iPart/iAssembly, external excel file), but I have a bunch of files I need to modify and because of a combination of factors It seems this method (If it's possible) should work best.
I've attatched both files. I would appreciate a detailed explanation of a workflow I should follow to reach my goal or solved example files I've attatched.
