Hi All,
So besides the HIGHLY annoying "Cannot solve at (or near) this point" error when trying to drive an assembly with more than one sub-assembly set to flexible, and Autodesk whom have stated they are investigating it since 2021 with no change, I have to suppress all but one of any of the flexible sub-assemblies in order to be able to animate the constraint drive. But then I found this new problem I can't seem to fix...
Running the drive tool back and forth, everything works perfectly, until I hit "OK", then everything goes to hell.
See attached video.
This still happens even after removing all flexible sub-assemblies entirely, and I have deleted all constraints and reassembled from scratch only to end up with the exact same glitch again.
Has anyone experienced something like this before and come up with a fix?
