"cut normal" not working on negative Coordinates
markus.weizinger
markus.weizinger
Hi all,
I have a Tube created with a turning operation.
The complete part is on the positive side of the center point of the y axis
The Extrusion is working.
When I move the turing sketch onto the negative side of the center point, the "normal cut" extrusion stops working.
This behavior changes, when the part is not a tube but a reduction. Or when the Tube is created by an extrusion.
Sometimes it works sometimes it does not. There is no real pattern.
Has someone a solution or explanation?
I need this to work in every szenario for a heavly automated process.
Thanks in adavance
JDMather
Why not use Sheet Metal functions to create this model rather than Revolution and Extrude?
Why not fully define sketches?
johnsonshiue
Hi! This has something to do with Unfold/Refold. Somehow Inventor has hard time unfolding or refolding the body after the cut is made (to create the proper cut faces). There are workarounds when it happens.
Option1: Move EOP above the Cut. Thicken -> uncheck Auto-Blending -> pick the gap face -> set a small distance. Repeat the step to the other gap face. Move EOP to the bottom.
Thicken creates short planar faces with straight edges so the Unfold/Refold has a clear reference to start.
Option2: Edit Cut2 -> uncheck "Cut Normal." Thicken -> uncheck Auto-Blending -> pick the inner cylindrical face -> set distance = 3cm (thickness) -> set operation to Intersect -> pick the logical direction. Repeat the process from outside.
Many thanks!
Software Test Engineer
markus.weizinger
You are right, the sketch is not fully defined. I wanted to illustrade my problem with a simple part.
How would you create a reducer with a defined total length? (Here From Edge to Edge 15)
markus.weizinger
Your Option 1 works kind of. On my first try i chose a small Value (0.0001) to keep the changes minimal. On my particluar Example the minimum Value to make this option work was 0.001. Otherwise i get the same Error. Is there a way to say what will work an what not?
As i mentioned i need this for an automated prozess. The Part can be a tube as well as a reducer. Your Option 2 works great for a reducer. But not for a tube. If the part is a tube then there are no changes made with the second thickening operation. So i get another Error.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
