Activate representation view in all subassemblies
Luis_Pacheco_3D
Luis_Pacheco_3D
I have an assembly with 92 subassemblies, I am trying to activate the representation view in all of them but it only shows Level Detail by default.
if I can activate view representation in subassemblies, I do this
exist a form to activate all at the same time? some configuration or ilogic rule?
Luis_Pacheco_3D
Solved.
pcrawley
This should work for you: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-view-representation/m-p/46750...
Read the rest of the post, because there are some cases where it may fail or not work as expected.
Peter
pcrawley
Can you post how you solved it, and mark it as solved to make it easier for other to find your solution?
Peter
Luis_Pacheco_3D
Select all subassemblies, right-click, select representation, and in the popup window select the view to activate.
Type a product name
