Mesh to CFD
TEDPOWERTRAIN
Mesh to CFD
TEDPOWERTRAIN
Hi  everyone
I have posted this issue on the CFD forum, since no one has replied, I decided to post this in here. I have an issue of the model not visible when I have done the surface wrap. Anyway, I still transfer the invisible model into the CFD setup and the problem is I couldn't set the boundary conditions and materials assign as you couldn't see the model.
Ted
Replies (7)
CCarreiras
You have to turn the mesh into solid.
A mesh is only a shell with no solid, so you cant assign materials to a shell, the shell has no volume, etc.
CCarreiras
TEDPOWERTRAIN
Hi
I didn't know what I have done wrong so I record a video.
Ted
admaiora
Hi, you have to follow what @CCarreiras  said.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
TEDPOWERTRAIN
Hi
The thing is I don't know how to do it. I am just a technology dinosaur.
Ted
admaiora
Convert a mesh model to a  solid model can be easy or very tricky, and that can depends by many factors.
Your model looks quite big.
Here a video
https://www.youtube.com/watch?v=2sSX5-SFbkQ
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=6950391119076900441&appLang=en&os=Win64
If you can attach the mesh model I can tell you more about it
Admaiora
TEDPOWERTRAIN
Hi
I have tried using mesh enabler, it doesn't work. Some Autodesk staffs told me that I can import my mesh model directly to CFD by using surface wrap.
Ted
CCarreiras
The issue is... i believe your surfaces are too complex, too detailed...
CCarreiras
Type a product name
