Inventor Forum
Drill Point
8 REPLIES 8
Message 1 of 9
rciesla
566 Views, 8 Replies
Drill Point
I am new to inventor and trying to create a faceted drill point. How would I go about this? I can't seem to manipulate the planes in multiple directions to generate this.
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: rciesla
@rciesla wrote:
I am new to inventor ,
A drill bit is probably a difficult challenge for a beginner.
The attached document shows how to do it in AutoCAD.
The process is essentially identical (except easier) in Inventor.
Attach your *.ipt file here if you have trouble figuring it out.
Message 3 of 9
rciesla
in reply to: JDMather
I have no problem with a twist drill. The problem is adding a primary, secondary and teritary relief to the point angle.
Message 4 of 9
JDMather
Attach your *.ipt file here and end all doubt.
Message 5 of 9
rciesla
I cannot send this file due to customer confidentiality.
Message 6 of 9
mcgyvr
Well... good luck then..
Not sure how we are supposed to help you if you can't communicate the intended orientation of planes,etc.. to create these unknown to us features..
I guess we can direct you to the help showing how to create different types of work planes..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
Message 7 of 9
rciesla
in reply to: mcgyvr
I am trying to create a work plane that is rotated at a certain degree angle in the YZ plane and tipped to follow the point angle that has been generated in the XZ plane.
Message 8 of 9
mcgyvr
Maybe you need to use the "Three points" option then??
Message 9 of 9
JDMather
You should be able to create a dummy file that exhibits the same geometry as your proprietary data.
Creating workplanes at any desired orientation/location is pretty easy once you get the hang of it.
