See, image below. "Can not attach the view", does anyone know what may cause it? The view (A) appears like expected. Very likely it could be fixed by deleting the A-view and create a new one, but I'm curious about the source.
It's a derived file that's only mirrored to fit of the opposite side of a machine and the base component does not have this issue. Sheet metal part.
Also: note the odd blue dot โ on the drawing. I can't figure out where it comes from or if it's related to the main issue. ๐
And no, at this point can't upload the files.
No clue about the view message, seems very odd. Could the blue dot be an unattached point? Does the Design Doctor show any errors?
@EdvinTailwind
Hi Edvin! The blue dot makes me wonder if somehow the view definition sketch in the main view became de-attached from that view. (the circle) The fact that it is a full circle instead of open with arrows makes me think the attachment got lost. Maybe try dragging the blue point back over the circle in your main view and see what happens?
Chris Benner
Industry Community Manager โ Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Hi! This could be geometry related. Somehow Inventor could not attach the detail view to a piece of geometry in the drawing view. Try this. Open the part or assembly -> Manage -> Rebuild All. Or press Ctrl+F7 (make sure C:\temp exists) to see if there is a body quality issue.
Please share the files with me directly johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
I had to move on (and start my vacation ๐) and had to fix it before pre-releasing the files, even though the cause was unknown. As suspected all I had to do was delete the A view and create a new one. Right now I won't be at work for a few weeks, but maybe I can restore the faulty file from Vault later.
Was the view attached before? What if you detach and re-attach. Maybe it lost the "attachment point" reference?
