Message 1 of 10
Hi all,
I have a chamfer that i need to dimension in a drawing. The chamfer is a 1/8" x 90°. The Chamfer Feature tool in the drawing will not properly dimension in.
Trying to come up with a way, I added a sketch to the drawing to show the extended lines to dimension from. HOWEVER, once I am no longer in the sketch environment, I cannot dimension the sketch lines.
This sketch shows the purple sketch I created an the sketch dimension while in the sketch environment.
Is there a better way to show this so the shop understands it? I have added a picture of the extruded plate so you can see where this is coming from.
Thanks, Steven
