Drawing Representation not correct
Message 1 of 8
I am using Inventor 2019.  If I select the representation in my model, the model shows the correct representation of my assembly. However, when I add a view to my drawing and select the same representation, I get an extra part in my view.  Any suggestions?
Replies (7)
Message 2 of 8
Mark.Lancaster
@Anonymous
Are you talking about a LOD, View, or Positional representation?
Mark Lancaster
Message 3 of 8
View
Message 4 of 8
Sergio.D.Suárez
Hi, could you attach some descriptive images of the problem?
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 5 of 8
Cadmanto
Does this thread speak to your issue?
https://forums.autodesk.com/t5/inventor-forum/view-representations-do-not-update-in-drawings/td-p/58...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 6 of 8
I tried that but it did not change anything.  All I want is the bracket.  The model shows the bracket only but the view adds in a second bracket.  To fix it, I had to select the view from the drawing tree and turn the visibility off of the second bracket.
Message 7 of 8
SBix26
If you were able to do that in the drawing (select the bracket and turn off visibility), then your drawing view is not associatively linked to the model View Rep.  Edit your drawing view and check the Associative (link) box, OK.  Now the model view rep controls the visibility, and you are no longer able to change it in the drawing.
Sam B
Inventor Pro 2020.1.1 | Windows 7 SP1
LinkedIn
Message 8 of 8
johnsonshiue
Hi! The behavior does not sound right to me. It could be Design View corruption or bad bodies exclusion or pre-existing interference. Please share the files here so form experts can take a look further.
Many thanks!
Software Test Engineer
