Solid Sweep Error Inventor 2020
I am attempting to use solid sweep to cut a path from the target body but keep receiving a generic error.
"The attempted operation did not produce a meaningful result"
Is there something obvious that I am missing causing this to fail?
I have used the solid sweep tool before on other files and have had no issues until now.
j.palmeL29YX
Post the .ipt file please.
Jürgen Palme
attached is the .ipt file (solid sweep) and the derived part file(9603...)
johnsonshiue
Hi! There is very little chance this complex body would be able to sweep. I would try to simplify the body using Delete Face -> Heal or Shrinkwrap. The pockets, fillets, and holes need to be removed.
Many thanks!
Software Test Engineer
