Drafting Standards Guru's Question (Construction / Extension Lines)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm kind of old, and used to draw by hand back before this sorcery known as computers was invented. When drawing by hand when we had a dimension to something and further down the line there was another "something" that was supposed to be the same length and thus collinear, we would break the extension line around object lines but continue the line over to the next "something" to show that they were the same length.
That's a lot of words so there's a picture below.
My two questions for the drafting standards gurus are:
1.) Is creating these lines covered, mandated, or prohibited in any drafting standard that you know of (i.e. where did I learn to do this and is it correct)?
2.) Is there a tool in the drawing environment in IV that does this?
Currently we are left with either drawing one in using a sketch or using the centerline tool. What I need is a tool that works just like the centerline tool but with a different line type that way we could use it to connect auxiliary projected views and such.
