I have a assembly file .iam with tube and pipe segment in it. In contains few Run and within each run there are few routes .Is it possible to Download bending machine output file ( YBC ) table for all tubes at once without opening individually each run
Solved by johnsonshiue. Go to Solution.
@aswinsharingan
Hello, and welcome!
I do not believe that it is possible to get bending machine output from Tube & Pipe at all. @johnsonshiue can you confirm?
Chris Benner
Industry Community Manager ā Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
This brings up a question for me. As I have never done it, but am curious. Is there a way to get bending information out of a swept path or one made by the bend part command? Lets say I needed to model a brake line. Is there a way to export that to a tube bending machine? Maybe there is and I am not aware?
Hi Folks,
I am not aware of an out-of-the-box workflow to do that.
Many thanks!
@aswinsharingan Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
