Inventor Forum
Download YBC Table for all tubes in a asembly
6 REPLIES 6
aswinsharingan
198 Views, 6 Replies
I have a assembly file .iam with tube and pipe segment in it. In contains few Run and within each run there are few routes .Is it possible to Download bending machine output file ( YBC ) table for all tubes at once without opening individually each run
Labels (2)
6 REPLIES 6
CGBenner
in reply to: aswinsharingan
@aswinsharingan
Hello, and welcome!
I do not believe that it is possible to get bending machine output from Tube & Pipe at all.  @johnsonshiue can you confirm?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
blandb
in reply to: CGBenner
This brings up a question for me. As I have never done it, but am curious. Is there a way to get bending information out of a swept path or one made by the bend part command? Lets say I needed to model a brake line. Is there a way to export that to a tube bending machine? Maybe there is and I am not aware?
Autodesk Certified Professional
Hi Folks,
I am not aware of an out-of-the-box workflow to do that.
Many thanks!
Software Test Engineer
CGBenner
@aswinsharingan Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
aswinsharingan
@CGBenner  thanks for the reply. Sorry for the delayed response
Please find the attached picture.
In picture- steps of benign machine output generation
1. Activate the tube and pipe run in the assembly
2. Activate the Run.Run01 in this case
3. Right click on the pipe sweep. Pipe sweep in this case . A pop up opens in that you can select the bending machine output .
On the window that opens you can download the bending machine in YBC format. See picture 2 bending machine output file.
Normally I have to go to each pipe sweep to download the bending machine output file in YBC format. If there are N pipe sweeps I have to do that N times.
Is there a way to download all the bending machine output file in YBc format in an assembly at once
CGBenner
@aswinsharingan
Hello again.  Based on the response from @johnsonshiue this is not possible without some kind of customization.  I recommend asking this question in the Inventor Programming forum, to see if anyone has any ideas for a programming solution to this.  Good luck!
Chris Benner
