I was under impression - that particular design had been sorted out years ago,
Apparently - not. Or the OP just didn't look up the archives.
Cheers,
Igor.
The hole in a repad, theoretically the intersection of two perpendicular cylinders, is not an ellipse. An ellipse will get you close enough for any reasonable manufacturing process, but this topic has concentrated on theoretically perfect, not just close enough.
An ellipse is the geometric intersection of a plane and a cylinder. If the plane is perpendicular to the cylinder, the result is a circle, which is a special case of an ellipse. I created a geometrically (nearly) perfect repad, created a flat pattern and a drawing of it. Below is a Flat Pattern view with measurements at various angles of the section width, and an ellipse sketched at the center in red. As you can see, it does not match the center opening exactly. This is reasonable, since a circle through a cylinder, flattened, is not geometrically an ellipse.
I've attached my (nearly) perfect repad model (Inventor 2025 format), but I note that this is more work than it is worth, given manufacturing tolerances. Does the ASME code specify how consistent the repad ring width must be? Everything in fabrication has a tolerance, just as everything in modeling does. Typically, we would like for modeling tolerances to be orders of magnitude tighter than manufacturing tolerances, as they routinely are.
For those on previous versions, this is the model process I used:
But still-- how close do codes require us to be to perfectly uniform width?
Sam B
Inventor Pro 2025.0.1 | Windows 11 Home 23H2
what you have is more precise than required. yes, this is way more work than it should be.
This version is even more perfect (consistent width to 7 decimal places) and simpler to produce. I guess if you're doing this every day, you would want a dedicated tool to do the job, but for occasional use this is pretty reasonable in my estimation. Inventor 2025 format.
With two-way symmetry I decided it is easier to model a quarter of it and mirror twice; also makes Unfold/Refold simpler.
Sam B
