Document Tabs Have Disappeared and My Home not working after latest update
jkargasAC
jkargasAC
I updated my Inventor 2018 with the latest updates through the Desktop App and the document tabs for switching between files have disappeared and none of the buttons in the My Home ribbon do anything.  Anyone had a similar issue and what fixed it?
I've attached a screenshot of what Inventor looks like on open (typically would have had the home screen here but it has disappeared) and when I have multiple files open (no tabs along the bottom anymore).
Thanks in advance!
Jeremy
Cadmanto
Under the "View" tab, go here.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
MechMachineMan
2 options:
1. Try going to View > User Interface
     - Should be able to expose things here.
If that doesn't work:
2. Use the Inventor Reset Utility as found on your file system.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
johnsonshiue
Hi! Just go to View -> User Interface -> check Document tabs.
Many thanks!
Software Test Engineer
jkargasAC
It's already checked under the view ribbon.  I'll try the reset utility.
jkargasAC
The reset worked!
Met-Chem-Eric
Community Visitor
Community Visitor
That did it
Thank You
