Windows 10 Fall Creator Update - Inventor performance issue
Message 1 of 69
Dear all,
I have experienced performance issue after installing the latest Windows 10 Fall Creator Update. I had to wait about 5 sec to invoke more then half commands in average. I have tried to disable all add-ins and looked for any solution without success. Installed all available updates. I was really desperate.
Finally I have tried to roll back to previous build and both Inventor versions (2017 and 2018) are running flawlessly.
I hope it will help.
Best regards
Josef
Replies (68)
Message 2 of 69
My 2017 won't even open after the update.
Message 3 of 69
Xun.Zhang
Hi Josef,
Thank for your information.
It sounds unexpected to me, I will follow up with project team to analysis the performance problem to see any clue we can identify.
Thanks!
Xun
Message 4 of 69
DannyHubbard
Josef,
What commands were running slow for you after Windows updated to the Fall Creators update? We have tried it here on several systems but aren't seeing any difference in the commands.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 5 of 69
DannyHubbard
What error are you getting when trying to start Inventor after the windows update?
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 6 of 69
Message 7 of 69
Hello Danny,
it was quite a lot of commands and it was the same for Inventor 2017 and even Inventor 2018. For example:
- in assembly: Constrain, Bill of Material, Pattern, Place from Content Center,...
- in part: Extrude, Loft, Fillet,...
- in sketch: Circle, Rectangle, Trim,...
- in drawing: Dimension, Bend, Welding,...
I customize Inventor a bit for my purpose with few Add-ins which I have made. I have disable them as the first step but it did not help.
I did not think about any reinstall as I red read some post here on forum. After roll back everything works perfect.
Josef
Message 8 of 69
mdavis22569
Hi Jof,
I have a Surface Pro 4 with this update... no issues.
Have you tried doing the reset utility?
Mike Davis
Message 9 of 69
Hi all,
I have found the source of the performance issue. It is antivirus ESET. Performance issue disappeared after I uninstalled antivirus.
I will update my post when I will find the right antivirus setting.
JoF
Message 10 of 69
Giovanni.Eggermont
Hi Gents,
For what it's worth, I can state to be suffering the same "lag" issue with several of the commands. The worst behavior I get is from constraint and flange (sheet metal). I also think it has something to do with latest windows version (1709). I've addressed this issue to autodesk and hope they'll find a proper solution soon, because now it kills my workflow so badly.
Message 11 of 69
Hi Gents,
as I wrote I have found the root cause for lags and it was the antivirus I was wrong. All the lags came back.
Finnaly I had to reinstall my laptop and not allowed Windows 10 to update itself to latest version.
JoF
Message 12 of 69
Giovanni.Eggermont
It might sound strange, but it's rather satisfying to hear it wasn't your anti-virus...
  1. I was experimenting with it myself, disabling all processes, firewall,... and so on.
  2. Thought it was my "3D-connection" mouse/software that was interfering with Inventors latest update.
  3. I also use a "Razer Naga Epic" mouse and was thinking that it was the "Razer synapse" cloud based software that was causing this issue.
Nothing really helped untill I've start thinking about the "Windows Fall Creator Update".
(Even in Excel, windows 1709 makes the cursor flicker while typing something in cells)
Unlucky for me, it wasn't an update but a straight-on installation, so I can't switch to an older version of Windows - as there is none.
As mentioned before, I've adressed this to Autodesk and already received a probable solution (which didn't help by the way).
(They thought it had something to do with my virtual page file that wasn't set correct...)
So, I must keep working on a very, very, very sluggish inventor system, which is making me go bold, pretty fast. Smiley Frustrated
Hope they'll find a solution soon, as 6 seconds to open a command is something else!
Best Regards,
Message 13 of 69
Xun.Zhang
Hi All,
The problem now reproducible in my end with 4~5 seconds delay finally.
I will follow up with project team to see any root cause for it.
Xun
Xun
Message 14 of 69
Xun.Zhang
Hi again,
Can either of you try the temporary solution below and report back the result?
Try to uninstall KB4043961 update.
Thanks as usual!
Xun
Message 15 of 69
Giovanni.Eggermont
Dear Xun Zhang,
I've uninstalled the update "KB4043961" as requested,  without any results...
After rebooting, constraining goes faster but as more time passes, the 5 sec. delay is getting back.
(the same behavior as when the update was still installed.)
Best Regards,
Message 16 of 69
Hi Xun Zhang,
I have the same experience. I tried to uninstall some windows updates, uninstall different drivers or tried different versions. At the end I uninstall antivirus. Each time I uninstalled something the performance was improved for while but it came back.
Finally I had to reinstall my laptop and now I run all Autodesk products without any problem. Honestly I am afraid to update to latest Windows update. Maybe I will get spare laptop so I will try to update windows to latest update and test it.
Best regards
Message 17 of 69
AtleOdegaard
Just want to join in, I have the same problem. Same on both my computers, one of which is a completely fresh windows install 2 days ago. This was installed with a  Windows 10 pro 1709 ISO.
I use Inventor 2017, and placing constraints is now driving me nuts Smiley Mad
Message 18 of 69
Giovanni.Eggermont
Dear all,
I've received following message from Autodesk concerning ongoing issue:
This issue is now logged with development and you can follow progress by checking the current status of the following Article.
The article is being published to AKN but might take a few hours before it becomes available. I will now close this case as any updates will be reflected in the above Article.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Let's hope it will get fixed soon...
Best Regards,
Message 19 of 69
AtleOdegaard
Is there any progress on this?
Message 20 of 69
djeffries2
I would also like to know. Updated to 2018 finally, problem remains. Constraining box takes 15+ seconds to open with my PC going into "not responding" mode before it finally loads. Really slowing me down.
