Do iLogic Cope
Do iLogic Cope
Message 1 of 8
Do iLogic Cope
Imagine, you have to place  array of scale-down holes on a nonplanar surface. Is it possible to implement this problem through iLogic function? And use it in the future for different surfaces?
2017-01-19_170716.jpg2017-01-19_170938.jpg2017-01-19_171141.jpg2017-01-19_171329.jpg2017-01-19_171524.jpg2017-01-19_171603.jpg
Replies (7)
Message 2 of 8
Ron_Jones1122
You would need some point of reference for iLogic to work. If you always have points and planes then yes you could make it work
Ron Jones
Engagement Manager
Blog
LinkedIn
Message 3 of 8
OK. Thank you. And how to make an array of holes with the diameter reduction?
Message 4 of 8
Ron_Jones1122
I would draw the holes with specific parameter names for the diameter. you could then drive this in iLogic.
Ron Jones
Engagement Manager
Blog
LinkedIn
Message 5 of 8
And how to get rid of errors in the operation of the extrusion holes?
Message 6 of 8
Ron_Jones1122
Can you include the part file?
Ron Jones
Engagement Manager
Blog
LinkedIn
Message 7 of 8
attach a file to your message?
Message 8 of 8
Curtis_W
Hi E99A5E0BA,
I think this can be done. However... It will beyond the "native" iLogic abilities, and require Inventor's API.
I would encourage you to close this thread and start a new one on the Inventor Customization forum :
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
Post your example file on that new topic if you can, and I suspect someone will take on the challenge. Smiley Wink
I hope this helps.
Curtis
