Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
DIVIDING AN ARC IN A SKETCH INTO EQUAL SECTIONS
kadscad
Message 1 of 18
kadscad
how do you divide an arc in a sketch into equal segments without having to measure the angle or the distance along? I want to enter the number of segment and snap to those nodes.
Kirk
Inventor 2023
Replies (17)
Message 2 of 18
CCarreiras
Hi!
Circular array?
CCarreiras
Message 3 of 18
j.palmeL29YX
Maybe this workaround will help you:
https://autode.sk/2Q2jzHb
cadder
kelly.young has embedded your screencast for clarity.
Jürgen Palme
Message 4 of 18
kadscad
cadder
Thanks for that workaround, but that's nuts. Autodesk needs to incorporate a setting to divide an arc ,circle or ellipse equally.
Kirk
Inventor 2023
Message 5 of 18
JDMather
@kadscad wrote:
... Autodesk needs to incorporate a setting to divide an arc ,circle or ellipse equally.
I think that I would just do it the easy way.
Attach your *.ipt file here if you have trouble figuring it out.
Message 6 of 18
kadscad
a simple snap divisor is in order
Kirk
Inventor 2023
Message 7 of 18
j.palmeL29YX
I know you wrote "without having to measure the angle", but what about this:
https://knowledge.autodesk.com/community/screencast/030cbdbf-fa27-460c-a7e3-fb2238f9323d
cadder
Jürgen Palme
Message 8 of 18
kadscad
here is a simple solution that could be added. This is from another cad program
Kirk
Inventor 2023
Message 9 of 18
SBix26
How many segments are we talking about here?  Dozens? Five?
I think the quickest way to do it is to sketch that number of lines, connected to the arc, and make them all equal.  Now you have the points to add your centerpoint arc segments:
Edit: If you need to do this frequently, it could be automated with iLogic, for example.
Sam B
Inventor Pro 2019.1.1 | Windows 7 SP1
LinkedIn
Message 10 of 18
NigelHay
a simple snap divisor is in order.... just like you can do in AutoCAD?
Message 11 of 18
SBix26
Microstation, like AutoCAD, can do that because there are no constraints involved.  You can change the snap divisor as many times as you wish, and the placed geometry never moves.  The snap divisor in those programs enables precise placement of geometry to those points, but there is no constraint holding them there.  They stay there because that's where they were placed.  If you move the arc, the lines stay right where you originally put them.
That's not how Inventor (nor SW, SE, etc.) works.  What you're asking for is a new kind of sketch constraint, one which would be useful on occasion, I'm sure.  But how do you expect these lines to behave if the arc is modified or moved?  They should stay connected to it, and remain equally spaced, right?  And you should be able to change the snap divisor so the number of segments increases or decreases?
I think an enhanced sketch pattern tool could probably accomplish what you're asking; the Pattern tools for part features can follow paths and space a certain number of features along the length of the path.
But it's possible that your modeling task could be done in a completely different way, maybe even a better way.  Feel free to post here and see if anyone can help you out.
Sam B
LinkedIn
Message 12 of 18
JDMather
You guys are all doing to much work?
Message 13 of 18
kadscad
can you post how you are accomplishing this? I agree with  youthese ways are to much work for something that should be so simple
Kirk
Inventor 2023
Message 14 of 18
JDMather
It is your problem, not mine.
Every time I see something like this I think, "I must be missing something in the problem description?"
And then the OP changes the problem on me.
Attach your *.ipt file here, describe exactly what you want and I will demonstrate my Easy Button "solution".
Message 15 of 18
kadscad
Gee thanks. Why bother commenting if you are not willing to help. I don't have a sketch that I saved I just played around with it to see how it could be accomplished
 quickly
Kirk
Inventor 2023
Message 16 of 18
WHolzwarth
I'd do it this way (2018 IPT)
Walter Holzwarth
Message 17 of 18
JDMather
You will have more predictable results if you set Orientation - Direction1.
Especially if the path is more complex or if you use for features or use for placement of Components in assembly.
Message 18 of 18
3DAli
I used to work on a project that I had to this frequently and it was not an arc, it was a curve, best way, copy it into AutoCAD, use divide command, copy and paste it back into your sketch, done! fast hassle free till they add this useful command to sketch in Inventor.
