Disclose Instance Parameters on BOM/Part list
Jakob_hanssonTX9GL
Jakob_hanssonTX9GL
I a part with several instances that i want to give a personal value and disclose it on BOM/Part list. It would also be nice to use same parameter to Ballons and surface texture etc, should be possible?
Anyway i can't get it to work.
I have made my own parameter in Instance Properties.
In the BOM list,
I want each individual value for the same party to be reported separately.
I would like to have something similar in the part list aswell, but of some reason it can't find my parts value
It feels like it should be possible to use the same parameter?
kacper.suchomski
A few days ago @Curtis_Waguespack  had a similar problem:
https://forums.autodesk.com/t5/inventor-forum/parts-list-mark-numbers-instance-properties-question/t...
Kacper Suchomski
SharkDesign
Did you try clicking the gear icon and turn off merging?
  Inventor Certified Professional
Curtis_Waguespack
@Jakob_hanssonTX9GL ,
In the Bill of Materials, you can use the button indicated with the red arrow in this image, and unselect the Merge Part Number option, to see if that provides a solution for you.
Hope that helps,
Curtis
Jakob_hanssonTX9GL
It worked out great, thanks!
Do you know if therer are any similar functions for part list for a drawing?
