Hi.
I have an issue that while working to create a Inventor drawing, working with Inv. Pro. 2020.1, I experience that the section view position definitions is disappearing during drawing creation, ref. picture 1 & 2. The actual section views is still in place on the different sheets in the drawing, it is just the position definitions (A, B, C and D) on the "mother" view that disappear (the sketch for the section view is still in place and showing in the browser).
The workflow is that I started a new drawing template, I positioned out the main mother view on the drawing sheet 1. Further I put on several section view on the mother view. The section views is moved to sheet 2 and 3. I further continuing detailing the views on sheet 2 and 3. When I then went back to sheet 1, I experienced that the section view position definitions was missing, still all section views still was in place on sheet 2 and 3.
Solved by SBix26. Go to Solution.
If anyone wants to try to reproduce your results, they will need to have some files to work with and to know what version of Inventor you're using.
Sam B
Inventor Pro 2022.2 | Windows 10 Home 21H2
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Hi.
Thanks for feedback.
I have now updated my case with more details.
Related to files, I have fixed my drawing and it works fine now, but do you still think it would be useful to share a file package including the drawing and part/assembly files?
Hi.
Related to files, I have fixed my drawing and it works fine now, but do you think it would be useful to share a file package including the drawing and part/assembly files?
If you've fixed it, then I don't think we need to pursue it further. I note, though, that you are using a pretty far outdated version of Inventor 2020. You need to apply update 2020.4, followed by update 2020.4.3.
Sam B
Hi.
I agree that it would be useful to update to service pack 4.3 and then monitor if the issue happens again.
