Disadvantages Vault Basic
johan.degreef
Advisor Advisor
johan.degreef
What are the disadvantages of using Vault Basic? For example; I understand that all inventor files (no matter if they are checked out or checked in) are always "work in progress". What does that mean? They are not protected against double edits?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
swalton
All versions of Vault provide the following basic services:
  • Central storage of Inventor Files
    • Can be configured to keep a copy of a file each time it is checked into Vault
    • Check-in generates a "Version" of a file
    • Administrators can purge various historical versions
      • Vault Workgroup and Professional can leverage Lifecycles as part of a purge process.
  • Database that tracks the parent-child relationships between various Inventor files
  • Database that tracks which user has an active edit permission on a file
  • Tools to inform users if their local copy of a file is the latest from Vault, or has a newer version that needs to be downloaded to their local hard drive
  • Tools to copy entire designs to new files.
  • A backup utility to capture both the Inventor files and all the database and user information spanning the history of the Vault
Vault Workgroup and Professional add some additional features.
  • Categories: Administrator defined classes of design files.  Vault can assign files to different Categories at initial check-in.  Different Categories can have different Lifecycles, Revision Schemes, and other various features.  Vault can use Categories to limit what files or folders that individual users or groups of users can see.
  • Lifecycles: These Vault objects track the state of a file as it moves through a company's design process.   These supersede the Inventor "Design State" iproperity.  These are typically customized for each category and company.  Administrators create Lifecycles and define the possible transitions from one stage to another.  The Job Processor can be configured to create .pdf, .stp, or other output files based on Lifecycle state changes.  Various Stages can be configured to prevent editing by users.
  • Revision Schemes: Vault Revisions superseded the Inventor "Revision" iproperity.  The schemes define the starting letter or number and the sequence of letters/numbers.
When a Vault Basic user checks-out a file, they have edit permission and other users do not.  Once the file is checked in, other users can download the new version and check it out at any time.  Vault Workgroup and Professional can apply Categories and Lifecycle States to keep users from editing files without starting a formal revision process.
Steve Walton
Inventor 2025
bradeneuropeArthur
For Vault Basic it means with each check out you create a version.
So working with two person on the same file is not possible because they are checked out to one user and are locked by Vault.
Vault pro works the same but has additional features that makes it impossible to change released files.
This can also be a struggle!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
