Disabling specific prompts Inventor 2024
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
We use frame generator to quickly generate some parts based on a layout. Once these are made (and shortened) we always promote these parts to regular parts to remove the unnecessary complexity of frame generator.
When doing this you get the following prompt:
Now in Inventor 2022 we were able to check the "Do not show this message again ever" and select no, but in Inventor 2024 you are no longer able to do this apparently (it's greyed out).
I already tried looking it up in the application options "Prompts" tab, but this list is impossible to navigate. Still the few listings that looked like they could be controlling the prompt didn't do anything.
I even already went as far as exporting the application options and comparing the xml against the one we had from Inventor 2022, but alas this also didn't work since Autodesk apparently changed ALL the names of these messages.
Does anyone maybe know which command controls the frame generator restructure prompt?
Thanks!
