Dimensioning Lines in Sketch View Gives Different Dimensions
patrickKYHHB
Observer Observer
patrickKYHHB
Observer
Observer
Very straightforward bug in Inventor 2025.3.1
Two dimensions going off the same parallel lines/points give two different results. The size is already implied with constraints/dimensions outside of the screenshot below. When adding a reference/driven dimension (for my own sanity check) I got the 0.068" dimension shown, but knew I designed this part larger than 0.1" thick. I added a second dimension without placing it and saw the exact dimension I was expecting.
I've had this happen multiple times now and didn't think much of it until I was stacking dimensions for multiple parts, manually calculating manufacturing tolerances, and knew this specific dimension that is critical seemed off.
Why can't I trust the dimensions in my sketches to be correct?
SBix26
Can you post the part here?  I've never seen this happen in more than twenty years using Inventor, and I'm wondering if it is a file corruption or something very unusual happening in this sketch.
Sam B
Inventor Pro 2026.1 | Windows 11 Home 24H2
hkilic896XF
Not unusual; it always happens for the first time of attaching any driven value dimension. This is the tiniest issue of 2026.1 ..😊
johnsonshiue
Hi! This is a bug. I believe either there is a corrupted parameter or the display state of the driven dimension is outdated. If you go to Manage -> Rebuild All. Does it help update the dimension value? Also if the driven dimension is deleted and recreated, does it work better?
Please share the ipt file here. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
patrickKYHHB
Observer
Observer
Another one. File attached, this part has been created, saved once, but never closed and reopened. I saved a second time as a save-as for this upload, and it still shows the dimension. Look in Sketch 5.
I couldn't upload the first file referenced because of proprietary design, but this is fine to share
SBix26
When I open your part and Sketch5, or just look at the Parameters table, I see the bad value.  Anything I change makes the driven dimension re-compute correctly.
However, I have no idea how to create a problem dimension like this.  As I stated earlier, I have never seen this in twenty+ years with Inventor.
Sam B
Inventor Pro 2026.1.1 | Windows 11 Home 24H2
patrickKYHHB
Observer
Observer
The fact I can do it first shot on a brand new part/sketch is concerning to me. Understandable to use the rebuild function for old parts migrated to newer versions, dynamic/Adaptive dimensions, etc, but this is a brand new part that's entirely static dimensions with this issue. Crazy.
