Dimensioning Lines in Sketch View Gives Different Dimensions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Very straightforward bug in Inventor 2025.3.1
Two dimensions going off the same parallel lines/points give two different results. The size is already implied with constraints/dimensions outside of the screenshot below. When adding a reference/driven dimension (for my own sanity check) I got the 0.068" dimension shown, but knew I designed this part larger than 0.1" thick. I added a second dimension without placing it and saw the exact dimension I was expecting.
I've had this happen multiple times now and didn't think much of it until I was stacking dimensions for multiple parts, manually calculating manufacturing tolerances, and knew this specific dimension that is critical seemed off.
Why can't I trust the dimensions in my sketches to be correct?
