Dimension tool tangent to the line i want to dimension
Hi guys, im struggling making this drawing, i have here a flattened piece of sheet metal (jip same one i couldn't extrude earlier after getting some help) as you can see it has those slightly less than 90 angles because its tapered but when i want to dimension it the dimension tool snaps to the page somehow and not tangent to the line im trying to dimension, same with the smaller segments. i know it only makes a .01 difference but im cringing here.
jtylerbc
Are you trying to get the dimension aligned with the almost vertical edge?
mcgyvr
post your ipt file and idw file..
and state the versions of Inventor you are working with..
Yes
jtylerbc
When placing a dimension, moving the mouse cursor will cause it to switch between creating a Horizontal, Vertical, or Aligned dimension.  However, because your angle is so small, it may be difficult to hit that sweet spot to click and get an aligned dimension.
Instead, after you have selected the geometry but before you click to place the dimension, right-click.  In the flyout menu for "Dimension Type", you can select Horizontal, Vertical, or Aligned (in this case, Aligned).  This will force it to the type you want, regardless of exactly where you click.  It is not possible to change this after placement of the dimension.
Also, note that the geometry you select is important as well.  If you select the top or bottom lines, you won't get the necessary flyout options, because it is implied that the dimension would need to be perpendicular to the line you selected.  You need to either select two end points, or select the almost-vertical line, to get the right options to fix your issue.
You sir are a legend, thank you.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
