Error applying patch to file c:\Config.MSI\PT7E84.tmp while installing 2017 R3
AndrewPotachits
Message 1 of 19
AndrewPotachits
I have Inventor Professionan 2017 R2 (buld 199) installed on my Windows 10 x64.
I'm trying to install R3, but having error:
I disabled antivirus, I ran Inventor Setup using Administrator, but nothing helps.
Clicking Retry button doesn't help.
Attached are the screenshot and log file.
Not sure what I can try.
Replies (18)
Message 2 of 19
Mark.Lancaster
@AndrewPotachits
Messages like that usually points to some corruption in this folder (C:\Windows\Installer\$PatchCache$\Managed\) structure..  But I don't know where..  Let me see if I can dig up some more info for you...
Update:  Also do you have any Inventor language packs installed and this Inventor is not based on the Inventor ETO (Engineering To Order) installation?
Mark Lancaster
Message 3 of 19
AndrewPotachits
@Mark.Lancaster
1. I don't have any language packs on my computer
2. Not sure exactly what does it mean, but I have this in about box:
About box
Inventor professional 2017
Inventor ETO 2017
Message 4 of 19
Mark.Lancaster
@AndrewPotachits
So most likely that's the issue you're having..  You have Inventor ETO installed.  It is my understanding to remove the ETO add-in, try to install R3 and put the ETO add-in back in.
Mark Lancaster
Message 5 of 19
AndrewPotachits
@Mark.Lancaster
Not sure how can I do that... I installed Inventor ETO as a single product, so I expect the R3 update would also update it as a single product.
Maybe I should verify whether I downloaded right version or not.
I will be on vacation during next two weeks so I won't be able to verify that.
Message 6 of 19
@Mark.Lancaster and @AndrewPotachits I running into a very similar situation when attempting to install Update 4.  I have uninstalled ETO and restarted my machine.  Here is the error I'm getting when attempting to install:
Attached is my install log:
Message 7 of 19
Mark.Lancaster
@Anonymous
Are you sure the update hasn't been already applied?  There should be numerous log files associated to this  installation in your personal temp (%temp%) folder.  Zip and attach here.
Also did you disable your anti-virus application while doing this install?
How did you install it?  Through your Autodesk Desktop App?  If so, go to your Autodesk Account and download it and then install it.
Mark Lancaster
Message 8 of 19
@Mark.Lancaster It looks like disabling the Antivirus resulted in the error being raised on a different file:2017-10-06_9-54-28.png
I do not have any updates installed.  I don't need to install the updates in order correct? They are cumulative?
I attached my log files.
The update I'm trying to install was downloaded from my Accounts.Autodesk site.
Message 9 of 19
I am still not able to apply this service pack.  Any suggestion would be greatly appreciated.
Message 10 of 19
Mark.Lancaster
@Anonymous
Your logs are showing that it can't update the core Inventor 2017.
Review this...
Mark Lancaster
Message 11 of 19
@Mark.Lancaster attached are the results of the AIDA applicaiton
Message 12 of 19
Mark.Lancaster
@Anonymous
I don't believe the AIDA works on updates.  Only for new installation of the product.
Do this as a test..  Go into Windows Control Panel/Program and Features/Add&Remove programs, located your Inventor, right mouse click and select uninstall/change.  Does the add/remove features, reinstall/repair and uninstall option appear?
Mark Lancaster
Message 13 of 19
Yes
Message 14 of 19
bob_holland
Autodesk Support
Autodesk Support
@Anonymous
This will happen when programs get updated out of sequence.
I would have you check for installed updates and remove all of you Inventor 2017 updates starting from the oldest to the newest:
You should see something like the following:
I would then reboot and use the Autodesk Desktop App to update Inventor 2017:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/About-Autodesk-desktop-a...
If this still does not work then you might need to Uninstall Inventor 2017 and start over:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\Uninstall Tool
Thank you.
Bob Holland
Autodesk Product Support
Message 15 of 19
@bob_holland
I uninstalled and reinstalled Inventor from Inventor_ETO_Dev_2017_Enu_Win_64bit_dlm I did not install ETO and I'm still getting the same error when attempting to install 2017.4.
Justin
P.s Sorry I'm writing this from Scott's computer.
Message 16 of 19
Any other options on how to address this issue?
Message 17 of 19
DannyHubbard
Looking at the log files the patch if failing when trying to update the file "C:\Program Files\Autodesk\Inventor 2017\Bin\Bin32\dwfcore_wt_ns.1.7.0.dll" not sure if this file doesn't exist or is corrupt.
You mentioned reinstalling Inventor but from the ETO install?
I would recommend re-downloading the Inventor Pro install files, http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk..., and uninstalling and reinstalling again.
After uninstalling make sure the file mentioned above doesn't exist prior to reinstalling, if it does manually delete it before reinstalling.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 18 of 19
This worked however is this how I should go about applying the patch to my clients pc?
Message 19 of 19
DannyHubbard
If the other clients are returning the same or a similar error, then yes I would recommend the same thing to allow the patch to be applied.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
