& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hi guys, im struggling making this drawing, i have here a flattened piece of sheet metal (jip same one i couldn't extrude earlier after getting some help) as you can see it has those slightly less than 90 angles because its tapered but when i want to dimension it the dimension tool snaps to the page somehow and not tangent to the line im trying to dimension, same with the smaller segments. i know it only makes a .01 difference but im cringing here.
post your ipt file and idw file..
and state the versions of Inventor you are working with..
When placing a dimension, moving the mouse cursor will cause it to switch between creating a Horizontal, Vertical, or Aligned dimension. However, because your angle is so small, it may be difficult to hit that sweet spot to click and get an aligned dimension.
Instead, after you have selected the geometry but before you click to place the dimension, right-click. In the flyout menu for "Dimension Type", you can select Horizontal, Vertical, or Aligned (in this case, Aligned). This will force it to the type you want, regardless of exactly where you click. It is not possible to change this after placement of the dimension.
Also, note that the geometry you select is important as well. If you select the top or bottom lines, you won't get the necessary flyout options, because it is implied that the dimension would need to be perpendicular to the line you selected. You need to either select two end points, or select the almost-vertical line, to get the right options to fix your issue.
You sir are a legend, thank you.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
