Is there any way through Inventor or Vault (or an add-in) that I can apply a Document Setting change to multiple drawing files at once?
About 6 months ago, I used some company standard drawing templates when creating the new templates for my project. Unknown to me the default dimension text alignment setting in Tools > Document Settings > Drawing was set to "View Position" (which I don't know why anyone would ever want). I now have some ~600 drawings that I'd like to change this setting on to "Percentage of Dimension Line".
My design is intended to be a master which is then copied using Copy Design in Vault to produce new model and drawing sets. The aim of which is to produce new design applications and/or versions with different proportions. It would not be unusual for one application to be 3 x the overall size of another.
Obviously, the current setting results in dimension text positions on the new drawing files that do follow the geometry well, making for a lot of additional manual editing of something that IMO should update parametrically.
Thanks in advance,
Noel
