Dimension Text Alignment - Apply Drawing Document Setting Changes To Multiple Drawings
NOEL_GETTINGBYCZTUC
NOEL_GETTINGBYCZTUC
Is there any way through Inventor or Vault (or an add-in) that I can apply a Document Setting change to multiple drawing files at once?
About 6 months ago, I used some company standard drawing templates when creating the new templates for my project. Unknown to me the default dimension text alignment setting in Tools > Document Settings > Drawing was set to "View Position" (which I don't know why anyone would ever want).  I now have some ~600 drawings that I'd like to change this setting on to "Percentage of Dimension Line".
My design is intended to be a master which is then copied using Copy Design in Vault to produce new model and drawing sets. The aim of which is to produce new design applications and/or versions with different proportions. It would not be unusual for one application to be 3 x the overall size of another.
Obviously, the current setting results in dimension text positions on the new drawing files that do follow the geometry well, making for a lot of additional manual editing of something that IMO should update parametrically.
Thanks in advance,
Noel
CCarreiras
Hi!
You can try this tool in the image below, but when i tested it in the past, it will only update the titleblock, margins... not the styles.
Regarding document settings never tried, so test it and give some feedback.
CCarreiras
NOEL_GETTINGBYCZTUC
No, the solution proposed above by @CCarreiras did not work for the Dimension Text Alignment setting. Any other suggestions folks? Autodesk?
johnsonshiue
Hi! I suspect this will need to be done using Inventor API or iLogic. I don't think Drawing Resource Transfer Wizard deals with document settings. Please take a look at the following discussion.
https://forums.autodesk.com/t5/inventor-programming-ilogic/dimension-text-alignment-with-ilogic/td-p...
Many thanks!
Software Test Engineer
NOEL_GETTINGBYCZTUC
OK so I see that this can be done via an iLogic rule when using the After Open Document trigger.
It remains to be seen whether the iLogic rule will trigger and apply before the dimensions update.
The next question is, how to open and save ~600 drawings without having to do so manually?
This is somewhat complicated by the fact that I work with external drafts people (overseas co-workers, external contractors, etc) and having to roll out an iLogic rule to them would be cumbersome.
johnsonshiue
Hi! To pursue iLogic solution, I suggest you go to Inventor Programming forum (https://forums.autodesk.com/t5/inventor-programming-ilogic/bd-p/120).
Below is a related discussion on how to run an external rule to open multiple drawing files. It should be doable. You need to create an external rule and link it to a drawing you already open. Then simply go through each document to make the necessary change in the Doc Settings.
https://forums.autodesk.com/t5/inventor-forum/how-to-apply-external-ilogic-rule-to-all-opened-docume...
Many thanks!
NOEL_GETTINGBYCZTUC
The example link you gave required the user to open a batch of drawings before running the rule, so it's of no use to me. Doing ~600 drawing using that method would literally take days.
At this point I already have an iLogic rule written which changes the Document Setting for an individual drawing and is set to trigger on drawings After Open Document.
ThisDoc.Document.DrawingSettings.DimensionTextAlignment = kMaintainAllTextAlignment
But to update the ~600 drawings automatically, I'll just use Inventor Add-In iLogic Rule Batch Tool to do one project folder (~200 drawings) at a time. I'm surprised you didn't suggest it.
