Dimension problems still
jeremy_wasserstrass
jeremy_wasserstrass
Okay, I thought I had my issues with views giving weird dimensions solved, however, I am still having the same problem. This time though I made a screencast so others can see what I am doing and what I am getting for results.
Using Inventor 2026 on Windows 11
Ideas needing support: spur gear tooth profile, rack gears generator
mdavis22569
If you RMB on the view what do you see for General Dimension Type ... Projected or True?
Mike Davis
jeremy_wasserstrass
The view is set to True. I knew there was something simple I was missing. So how did it get set that way, and is it a persistent setting?
mdavis22569
There is a bug for it ..  I saw this about a month ago and reported it ...
Change IDW view from ISO to Front Dimension issue
PR:1923
Mike Davis
