Inventor Forum
Dimension not snapping to centre marks
6 REPLIES 6
hEINSTEIN
488 Views, 6 Replies
Hi, I'm working from a clients drawing template.
I can't snap to any center marks. I have tried to make a sketch and project the point/lines I want to dimension to, and this also does not work.
Here is a screen shot of centered pattern I created, I'm trying to put in a angle dimension. Bit Inventor only gives me a vertical dimension.
This is what I want to show.
Could this be a setting in their template that I need to change?
Thank you
6 REPLIES 6
j.palmeL29YX
in reply to: hEINSTEIN
Post your file(s) please.
Jürgen Palme
johnsonshiue
Hi! In Inventor, two points don't define an angle. You need two lines (sketch or centerline) passing through the center points.
Many thanks!
Software Test Engineer
CGBenner
in reply to: johnsonshiue
@johnsonshiue @hEINSTEIN
If I understand the original question, I believe the user is trying to select the lines of the centermark from the rotational pattern.  This should work to dimension the angle between the lines of the centermarks.  I must ask, however, are you selecting the actual line, or at the center of the circle where the two lines making up the centermark intersect?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
hEINSTEIN
in reply to: CGBenner
Hi @CGBenner
Yes you are correct, it seems I cant snap to any lines or points of any center lines.
I have tried to draw in sketches and project the center marks, but it also doesn't want to snap to the sketches.
So I'm wondering if there is a setting that could have been set to prohibit me from snaping to these features?
j.palmeL29YX
Why you don't post an example file, so we can see what "center marks" you have?
Jürgen Palme
CGBenner
@hEINSTEIN
I think I am tending to agree with others, can you share a part file and drawing that are giving you this trouble, so that we can take a look at it?
Chris Benner
Technology Administrators
