Different types of threads in one iPart
Malenki
Malenki
Can I use diferrent types of threads (as variants), in one iPart/iFeature file, ex. M10x1.5 (ISO Metric profile) and G1/8" (ISO Pipe Threads)? Look at the file in attachment and correct it if possible, please.
Can anybody help me?
Kind Regards.
_______________________________________________________
Windows 10 64B + Product Design Collection 2021+ASM 2018
1. HP Z2 Tower G4: Intel Core i7-8700K CPU@3.70GHz + Quadro P2000
2. GIGABYTE EX58-UD5: Intel Core i7 920 (2.66GHz to 3.6GHz) + Quadro FX4000
alessandro.gasso
For switching from one thread type to the other in your ipart, you need to add the Thread: Class column in the ipart table, as you have done correctly, and explained in the blog post below.
http://beinginventive.typepad.com/being-inventive/2011/12/adding-a-little-class-to-threaded-iparts.h...
Unfortunately, the cell of this column cannot be empty.
So, since in your case, actually the class column for the internal ISO Pipe threads is empty, you need to do the following.
Make a backup copy of the file Thread.xls located, for instants on Windows 7 in the folder C:\Users\Public\Documents\Autodesk\Inventor 2012\Design Data
Edit the file and add a value for the class column for the rows where you need it.
Restart Inventor.
Edit the ipart table and add the value to the corresponding class cell.
I’m sending you back you ipart where I’ve applied this change.
It should work on your machine after you have edited the Thread.xls file of your installation as explained above and restarted Inventor.
I hope it helps.
Kind regards,
Alessandro
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Malenki
Thank You for satisfactory answer. It is good solution fot this time.
Kind Regards
malenki
