@Anonymous wrote:
did i doing it correctly ??
yes but all your colors are messed up..
Sky should be a light blue background,etc....
The background color of the scheme you were using has been modified too..
Seems like you (or someone else) either used the "ICE Inventor color scheme editor" or your registry is corrupt or something else is wrong..
Maybe try running the Inventor Reset Utility or just correct the colors with the "ICE Inventor color scheme editor"
well start here first..
Please show us a screenshot of whats in your c://users/public/public documents/autodesk/Inventor 2017/SDK folder
Mine looks like this..
and if you want to try the Inventor reset utility its located here..
Note: you may want to backup your application options first.. (tools..application options..and press the export button at the bottom) so that you can reimport and application options you have changed after running the reset tool and restarting Inventor..
