Difference in weight on part list (assembly and insert as sub-assembly)
Message 1 of 11
After creating an assembly I inserted this assembly in a the main assembly this went well, but when i was making the IDW-file then i notice something sttrange.
The weight (noted in the Part list) of de sub-aassembly was on the sheet of the main assembly about 375 kg, but when i'm creating an new sheet for the sub-assembly the part list on this sheet noted 48kg, for the same assembly.
I'm trying to find where this goes wrong, but i'm not finding it.
Don't understand why this and how this happens.
Does someone konw why this happens? And most of all how can i get the weights the same.
Greeting, Joop
Replies (10)
Message 2 of 11
Xun.Zhang
Sounds like two drawings are reference to different mass property.
Please open that assembly, iProperty -> Physical and update, what is the value listed there?
Thanks!
Xun
Message 3 of 11
Hello Xun,
they are both empty (so the same).
Greetings, Joop
Message 4 of 11
i found where the mass of 300kg came from. I made a box (extrusion) so i could create a frmae to use framegenerator.
This extrusion had a mass of 300kg. So now i know where this came from, but how can i keep this mass from the part list?
thanks, joop
Message 5 of 11
SBix26
Best way, I think, is to make your box for Frame Generator a surface extrusion instead of a solid extrusion.  Then it will have no mass.
Sam B
Inventor Pro 2020.0.1 | Windows 7 SP1
LinkedIn
Message 6 of 11
johnsonshiue
Hi Joop,
Please share the example here. The behavior does sound defective to me. Or, there is indeed slight variation in the geometry.
Many thanks!
Software Test Engineer
Message 7 of 11
Hello John,
share the sub-assembly? The main-assembly is too big to share.
Or do you what screenshots of the modelbrowser?
Greetings, Joop
Message 8 of 11
johnsonshiue
Hi Joop,
I need to see the files exhibiting the bad behavior. Does the subassembly show the wrong value?
Many thanks!
Message 9 of 11
hello Shiue,
do you need only the aim-file (sub assembly)?
Message 10 of 11
johnsonshiue
Hi Joop,
I need ipt and iam files.
Many thanks!
Message 11 of 11
Hello Shiue,
is changed the material to AIR.
This ofcourse temperorary solutions but i have a dead line on the project.
I'm learning ervery more and more of Inventor.
Thanks for your help.
Greetings Joop
