Did Split Features get changed from 2019 to 2020?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My company just upgraded from 2019 to 2020 Inventor, and I have an issue with one of our standard parts. The Master Cabinet part works by suppressing certain features for options, and I have a corner cabinet built off the base Master Cabinet where I split the top/bottom/back and rotate them to their corner cabinet positions.
Image below shows a portion of the workflow loaded up from a 2019 native file:
2019 model openned for 1st time in 2020
When you run "Rebuild All" my splits, and their children features get suppressed, because there are features higher up in the model tree that are suppressed for options:
"Rebuild All" causes split feature suppression in 2020
Is this a new intended behavior of the split feature? You can only use split feature if no feature is suppressed for a given solid body? Why was split feature the only one changed? Other features I tried don't get suppressed this way [Thicken, direct edit, rectangular pattern, fillet, etc.]
