We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Did I find a bug? Try to fillet both sides of this part if you want to find out.
mailswamp
mailswamp
Did I find a bug?
This skinny trunk thing meets the wheel. This is where I want to create a fillet around all
Model included. -- Inventor 2016.
WHolzwarth
It's tricky.
Feature pattern didn't work well, I had to use solid pattern  and re-combine instead.
Splitting to only 1/32 of the full circumference and pattern this would work,too.
2016 file attached.
Walter
Walter Holzwarth
JDMather
Here is my interpretation.
wilkhui
Hi mailswamp,
Using my build of Inventor 2016 I didn't see a failure when I deleted your Fillet6 and created it again, you might be short on a few updates.
Can you install the service pack and latest update from here and then try the fillet from scratch?
Cheers,
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
JDMather
Where did  you go?
mailswamp
Still looks like a bug that requires workarounds.
I found another bug that is definitely a bug.
The project geometry command just refuses to work.
wilkhui
Did you try updating your version of Inventor with the service packs and updates and then attempting the fillet?
Regarding the project geometry problem you're experiencing, you need to record a Screencast or tell us exactly what you're attempting. I didn't see any bugs when I was looking at your file.
Indy
Product Owner - ASM
Autodesk, Inc.
