I'd like to remove the scale call out under my detail views when I pull one. But I cannot find where to edit this in the style and standard editor. Can someone point me in the right direction?
Thanks!
What did you end up doing?
When I want to remove the scale from the view label, I just edit the view label and delete it.
Sometimes I do want the scale and this way gives me the option of having the best of both worlds.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Under your standard you change you click the view preferences and delete in the text field. I'll attach an image
