Inventor Forum
Inventor Bug Sketch Profile Recognition Fails To Connect Line Points
3 REPLIES 3
janelson33
385 Views, 3 Replies
So I'm drawing a part and have encountered what seems like a bug.
On Sketch2, it still thinks there is an open profile. I thought, "Oh maybe I didn't click the point when it was a green point," so I tried again, being deliberate to make sure the points were green. The problem resides at the point that the red arrow is pointing at. I have tried to redraw the line from either the right or left point first. I have tried the Sketch Doctor, and that fails to combine the points; that's when I realized something might be up.Problem_Point_and_Line.JPG
Here are my Application Settings for Sketches:App_Settings.JPG
 kelly.young has edited your subject line for clarity: Think I Found a Bug
Office Machine Specs:
- Dell XPS Tower
- Windows 11 Pro - 64-bit 22H2
- Intel Core i7-8700 @ 3.20 GHz
- 32 GB RAM
- NVIDIA GeForce GTX 1060 6GB
- Inventor 2022 Professional & Vault Basic installed on SSD
- Window Defender
Remote Machine Specs:
- HP Z2 Mini G4
- Windows 10 Pro - 64-bit
- Intel Core i9-9900 @ 3.10 GHz base
- 32 GB RAM
- NVIDIA Quadro P1000 4GB
- Inventor 2022 Professional & Vault Basic installed on M.2 SSD
- Kaspersky Internet Security Product Suite
3 REPLIES 3
mcgyvr
in reply to: janelson33
This forum has a bug right now in that it won't let you attach certain file types (ipt being one of them) unless they are zipped up..
So please try to attach your file again but zip it up this time..
johnsonshiue
Hi Jarott,
This has something to do with the way Inventor recognizes profile. Yes, it is a bug. Try this. Select the projected arc edge on the left and change the line type to Construction Line (dash line). Does it work better now? Inventor sketch profile recognition is constraint based. When there is missing or more constraint, the profile recognition can fail for no apparent reason from a user's perspective. We are aware of this deficiency and we are working on a solution. However, the solution will not be available on existing releases unfortunately.
Many thanks!
Software Test Engineer
janelson33
in reply to: johnsonshiue
Ok that makes sense. My projected edges were construction geometry in the pic. I cannot remember whether I switch them to construction after I made the normal sketch lines however; does that matter though?
I  can still post my file if you'd like, but perhaps it's not worth it since it's already a known issue?
I solved it by drawing a line in free space and then using the coincident constraint to mate the points.
- Dell XPS Tower
- 32 GB RAM
- Window Defender
- HP Z2 Mini G4
- 32 GB RAM
