Detail Drawing Orientation Error
joachimeng
joachimeng
I tried creating a detail drawing of a 3D model but the top, right, and isometric views seems to be inverted. How do I fix this? Please refer to the screenshot for clarity.
chenj
Hi, you can try switching the projection type,"First Angle" or "Third Angle".
joachimeng
Hi @chenj , thank you. It's working fine. However, I like to ask how do set it as default so I do not have to change it everytime
Gabriel_Watson
1) Edit your drawing template file directly and save the style changes, then save the drawing template.
2) After you modify the style to a different angle of projection as mentioned above, go to Manage > Save (styles), right there next to the bigger "Styles Editor" button. This will make sure the changes are also done to your Design Data for the project, so those will not clash with the newly changed templates.
You will need write permissions to edit the styles templates in your library, so make sure this change is vetted by everyone using it.
chenj
Before saving a style, you need to set "use style library" as "read-write" in the Project dialog box.
