The file in attachment has issues when making Cross sections in Design Review.
have tried out multiple files, installed the latest updates from both products (inventor and design review)
Consequence is: not possible to evaluate the design using design review.
Greetings
David Early
Edited by request
Discussion_Admin
I was able to duplicate this with your files. With my own, I was able to get the section views to work correctly, but could not shut off the cuts when i was done. The only way to revert is through the UNDO command, which also will undo anything else you have done!
@ChrisMitchell01... who would we talk to on the ADR team to bring this up?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Inventor generates Error while exectuting dwfx. Inventor marks no problem in the design doctor.
Greetings
David Early
Please ignore previous reply (error was logic, that problem is solved): had something to do with constraint error in a positional representation.
sorry for the misunderstanding, getting paranoid.
Greetings
David Early
