Inventor Forum
Design review: Problem Cross Sections
5 REPLIES 5
David_Early
418 Views, 5 Replies
The file in attachment has issues when making Cross sections in Design Review.
have tried out multiple files, installed the latest updates from both products (inventor and design review)
Consequence is: not possible to evaluate the design using design review.
Greetings
David Early
Edited by request
Discussion_Admin
5 REPLIES 5
cbenner
in reply to: David_Early
@David_Early
I was able to duplicate this with your files.  With my own, I was able to get the section views to work correctly, but could not shut off the cuts when i was done.  The only way to revert is through the UNDO command, which also will undo anything else you have done!
@ChrisMitchell01... who would we talk to on the ADR team to bring this up?
David_Early
in reply to: cbenner
No response from autodesk??
David_Early
Inventor generates Error while exectuting dwfx.  Inventor marks no problem in the design doctor.
Greetings
David_Early
Please ignore previous reply (error was logic, that problem is solved): had something to do with constraint error in a positional representation.
sorry for the misunderstanding, getting paranoid.
Greetings
David Early
Jon.Dean
Hi David,
I cannot open the DWFx file, I get an error "There was a problem displaying the file".
I can see the Thumbnails but that is all.
Is this the only assembly that is causing a problem?
If so, you could run it through the Task Scheduler using the task "Update Design" and checking "Rebuild All". It will also create a log file where you can check for errors.
Hope it helps.
Jon.
Jon Dean
Technology Administrators
