I know what you're thinking, and it's not that. 😉
I'm seeing the message 'The specified folder is not complete with all Design Data and style library files....' which I have seen before but this is different.
- I'm only seeing the message on my machine.
- I've checked it on other machines and it changes no problem.
- It's been pointing to these folders for over 18 months and they've been modified multiple times.
- I've already removed and rebuilt the HKCU Inventor registry keys.
- I've swapped out the Design Data folder with the default and still see the problem. (My DD is far removed from default so rebuilding from scratch is not an option)
Any ideas?
Craig
Hi.
Yesterday i had similar problem but with Undo folder.
I opened two inventor windows and Application Options, one with configuration that works ,and other with configuration that i want to change. I copied from one to another and worked for me.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Hi Craig,
You don't say which version of Inventor you are working with.
Would it be possible to Pack n Go your design data folder, so I can do some testing?
Let me know and I can send you a link to upload the zipped folder.
Cheers
Jon.
Hi Jon. I'm actually not back at work until the 9th. If you ping me a message with the link i'll see what i can do.
Also, using 2016 Pro.
