Trying to generate a hierarchy report but the button is greyed out. Ideas on why this is happening? Any other way to do this?
Solved by mcgyvr. Go to Solution.
Design assistant button? or the actual heirarchy report button? (just checking)..
Not sure what type of file you are trying to run this on but you can turn on "file path" column in the bill of materials if thats what you are looking for..
To use the Hierarchy Report, you will open an assembly with the "Properties" operation highlighted. If you have any other operation highlighted, it will be grayed out.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
