Inventor Forum
Design Assistant report hierarchy greyed out 2018
2 REPLIES 2
Mark.Valenti
289 Views, 2 Replies
Trying to generate a hierarchy report but the button is greyed out.  Ideas on why this is happening?  Any other way to do this?
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
2 REPLIES 2
mcgyvr
in reply to: Mark.Valenti
Design assistant button? or the actual heirarchy report button? (just checking)..
Not sure what type of file you are trying to run this on but you can turn on "file path" column in the bill of materials if thats what you are looking for..
jhackney1972
To use the Hierarchy Report, you will open an assembly with the "Properties" operation highlighted.   If you have any other operation highlighted, it will be grayed out.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
