Design Assistant: An error occurred saving changes. 80070057 process aborted
b.ziegler
Message 1 of 23
b.ziegler
I am using the design assistant to update the parts of an assembly during the revision process to maintain the relationship between mirrored components.  If there is an easier way to rename files and maintain the relationship between mirrored parts I'm all ears..  I've used this in previous versions of Inventor without a problem but we recently upgraded to 2022, and yes I have the latest update installed.
Here is the work flow that is leading to this error:
1. in my assembly I save and replace the body with body rev a
2. Close the main assembly
3. Open Body Rev A in Design Assistant
4. Select the subassembly "Body Right" and copy it to "Body Right Rev A"
5. Select Part "Panel Right" and copy it to "Panel Right Rev A"
6. Select subassembly "Body Left" (mirror component of Body Right), and copy it to "Body Left Rev A"
7. Select Part "Panel Left" (Mirror component of Panel Right) and copy it to "Panel Left Rev A"
8. Click Save
Normally this just updates the assemblies maintains the mirror relationship and I go on my way.
now I'm getting the error:
"An error Occurred saving changes.
80070057
Process Aborted."
Then all of my changes are reset.
Does anyone know how to fix this error or a better way to rename parts and assemblies while maintaining a mirror relationship?
Thank you
Replies (22)
Message 2 of 23
bradeneuropeArthur
Was it an Autodesk message or what?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 23
Chancellor.Kurre
Just had a customer with this issue. Try migrating all files to 2022 before using the Design Assistant. It looks like it no longer notifies of non-migrated files
Message 4 of 23
b.ziegler
Autodesk Inventor Design Assistant 2022
Build: 153, Release: 2022.0.1
Message 5 of 23
bradeneuropeArthur
@Chancellor.Kurre
Do you tell that the notification was removed about migration, is that correct?
Since when has that removed then?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 23
Chancellor.Kurre
@bradeneuropeArthur I do not know the official word on whether the migration notification was removed or not(or whether it was intentional), just a report from a customer that it did not appear when using the 2022 DA like it did with 2021. @johnsonshiue do you know what the expected behavior is?
Message 7 of 23
johnsonshiue
Hi Folks,
I was not aware of the behavioral change. I thought DA always required files to be fully migrated before they can be edited. I need to work with the project team to understand it better.
Many thanks!
Software Test Engineer
Message 8 of 23
bradeneuropeArthur
That would be a good idea @johnsonshiue .
Thanks for taking this serious too and again.
We (need to and) appreciate that.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 23
johnsonshiue
Hi Arthur,
This issue was indeed known (INVGEN-52625).
Many thanks!
Message 10 of 23
b.ziegler
Migrating the files seems to have solved the issue,  thank you for your assistance.
Message 11 of 23
frederic_joubert
I've got the same problem.
Migrating files to current (2022.1) version doesn't fix the problem.
Design Assistant still abort copying operation.
Any solution?
Message 12 of 23
johnsonshiue
Hi Folks,
I just checked the status of INVGEN-52625. It shows it has been resolved on an internal build targeting 2022.2 update. A testable version will be available on Inventor Feedback Community (https://autode.sk/InventorBeta) in early October.
Many thanks!
Message 13 of 23
ersin.bilgin
Will the problem be fixed with 2022.2?
Message 14 of 23
johnsonshiue
Hi! Yes, the fix will be included in 2022.2 update. A testable build is available at Inventor Feedback Community (https://autode.sk/InventorBeta).
Many thanks!
Message 15 of 23
ersin.bilgin
When will 2022.2 be released?
Message 16 of 23
johnsonshiue
Hi! Currently, it is scheduled in early November 2021.
Many thanks!
Message 17 of 23
ersin.bilgin
Okey tahank u
Message 18 of 23
Markus.Koechl
I run into the same error and cross-checked with @johnsonshiue; Looks likely that multiple reasons may result in the error. Some are resolvable by migration, others should be addressed by the mentioned update.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Message 19 of 23
I am fulllllly patched up (V. 2022.2) and I am still getting this error!!! UUGGGGGGG!
Message 20 of 23
Oh yeah, and the files have been migrated up to 2022.
