DerivedPart_SP not showing up in Add-Ins Manager
不适用
542 次查看
5 条回复
1 条消息(共 6 条)
不适用
I followed the tutorial published here to install the DerivedPart_SP add-in, but it never shows up in the manager. Is it not compatible with Inventor Professional 2017, or was a step skipped in the video?
0 个赞
已接受的解答 (2)
543 次查看
5 条回复
回复 (5)
2 条消息(共 6 条)
mdavis22569
That's from 2015...
what are you trying to do?
if you're trying to scale items ..you can do that 2 ways now
Direct Edit
Derived
Mike Davis
0 个赞
3 条消息(共 6 条)
不适用
I'm trying to scale a solid object along the Y axis. Is there a more up-to-date resource? The SDK usertools are all still present, they simply don't do anything when installed.
0 个赞
4 条消息(共 6 条)
mdavis22569
已接受的解答
look at my last posted I updated it
In 2016 and up it's in 2 different commands
and you can do what axis you want, in the direct edit way
Mike Davis
5 条消息(共 6 条)
CCarreiras
已接受的解答
Hi!
Just use direct tool with non uniform scale
CCarreiras
6 条消息(共 6 条)
不适用
Ah, I see now! Thank you!
