How to edit an STL file in Inventor 2016
Message 1 of 14
 Hello everyone!! So basically I am trying to print out some items that I found some .stl files of. The only thing is that my printer does not have any kind of support material so I need to slice the .stl in half to print nicely. The only problem is that I have yet to find any software that can do this. Below is what I have tried:
SketchUp 2016: imported stl and managed to slice, but exporting exported the whole object un-sliced
FreeCAD: imported .stl and exported as .dxf, .dwg, .stp but nothing could be opened in Inventor
Inventor: installed Mesh Enabler and did the whole "convert to base feature" process, which gave me a bunch of lines
What I need is to somehow get the stl file imported to some software, sliced in half, and export each side as an stl either one file or two works.
Any ideas?
Replies (13)
Message 2 of 14
mcgyvr
Post your part if you can't figure it out (post the ipt after you have performed the mesh enabler function and saved it as an ipt)
If you used the mesh enabler you should have a 3d model that can be edited (use extrude to cut it in half)
or after mesh enabler go to environments..3d print and use the partition tool built into that environment to chop it in half..
Message 3 of 14
So I got the stl file in and did the base feature into a solid and deleted the original. I then went into the 3D Print environment and now I don't know how to get the part into the environment
Message 4 of 14
JDMather
No, no, nooooooo  don't delete the original until you have solved the problem.
(actually, now that I open your attachment - I see your original mesh is still in this file)
Your browser shows that you have a Surface Body, not a solid?
Also,
iProperties indicates that you have not installed Service Pack 2.
Message 5 of 14
i did what the other guy said (sorry other guy i forgot how to spell your name). i still have the original file, whats deleted in the stl form in inventor. im not sure what a surface body is
Message 6 of 14
JDMather
@Anonymous wrote:
.... im not sure what a surface body is
I don't think you are ready for editing stl files.
I was able to get these parts to solid (grey) but not the surfaces (orange).
I didn't really spend any time on it though.
Wouldn't it be more satisfying to model it yourself?
You can use the imported mesh as reference.
Message 7 of 14
How about being a little less discriminating and a little more helpful. I'm sure at some point you were inexperienced with this too
Message 8 of 14
JDMather
Sure.  I will help you out in learning Inventor step-by-step.  This looks like a fun project.
I estimate that it will take about a month of work.
I can begin the instructions as soon as you let me know that you are ready.
Message 9 of 14
I've been using inventor for eight years, starting with inventor 2012 i think. I know how to use the main functions, just havent experimented with stl files before. Keep in mind you've probably had teachers that told you how to do things. I've been teaching myself because all the decent classes are way outside my price range
Message 10 of 14
Nah screw it I'll do it myself
Message 11 of 14
HEY can someone help me ???
I have been surfing the net for days on how to convert a imported stl file in inventor2016 from wire mesh to solid form so that i can attach it to my another part.
Message 12 of 14
JDMather
Try opening the attached file.
Message 13 of 14
Coming back to the original question to cut a .stl part in half:
I am using Meshmixer all the time to cut my stl parts in separate parts to print them nicely. Meshmixer is from Autodesk and it's free.
Kind regards, Frank
Message 14 of 14
JasonFralin
Community Visitor
Community Visitor
_
