I created a sketch on a face that was not the one I actually wanted, so I tried deleting it. Even though I didn't even sketch anything on it, once I deleted it, Inventor messed up a bunch of things coming before that sketch on the model hierarchy. I checked dependencies, and this sketch has no children whatsoever, so I have absolutely no idea why it's behaving the way it is.
I'm aware what I'm modeling isn't exactly what Inventor is for, but I wanted to get something done quick.
I'm attaching the file with the model that is behaving weirdly. Sketch 18 is the problematic one. I repeated what I did and created sketch 19 to see if it would behave just as weirdly, and indeed it does.
Anyone have any ideas on what is happening? Is this a bug? Thanks.
Solved by James_Willo. Go to Solution.
@joao_fragaMGVEE sketch 18 has a projected point at the intersection of red and blue, if you left button click, and drag over your whole work area that point comes up, and sketch 19 has the same point, there might be an easier way of making what you are making... but what is it?
Hi, this has nothing to do with the sketches on the end, when you first open the file you'll notice there's a lightning bolt for refresh in the top
Work plane 3 needs fixing. You can use 'redefine feature' or 'recover' on the right click menu.
Ooohh, I see it now. Was it created automatically because I created the sketch on that circular face, so its centerpoint was projected? I don't remember every selecting "project geometry"... but why does a projected point lead to this kind of behavior?
I'm trying to construct a quick-and-dirty 3D diagram of a spherical RR linkage.
Thanks for replying.
Thank you! That fixed it. I'm wondering now why it happened in the first place... I don't recall ever changing any of the elements used to define that plane. Also, why did this problem appear only after I created that sketch? The model updated several times before that without issue.
I'm not sure, but I think that after you delete the sketch, Inventor is then doing the refresh for you.
@joao_fragaMGVEE If it was me I'd create some user-defines parameters and create some relations, as it is now, your model shares a lot of the same values, (not sure if they are tied to one another), but it's easier to handle this stuff in a form that can stay open while your working, then you can model in real-time seeing changes take place
@joao_fragaMGVEE In your part parameters, you've used the dimension (30 deg) 3X, (1mm) 3X, (30mm) 3X, (45 deg) 2X, (75 deg) 3X, etc. My point is, you're hand-typing the dimension each time, which means if those constraints share the same number, when one changes the others will not. Would you like them to all update if one changes?
